www.www.bussiapp.com
Forum SubscriptionsSubscriptionsDigestDigest PreferencesFAQFAQSearchSearchMemberlistMemberlistUsergroupsUsergroupsRegisterRegisterFAQSecurity TipsFAQDonate
Use online scanners
on Licensing Issues
This forum is locked: you cannot post, reply to, or edit topics.This topic is locked: you cannot edit posts or make replies. www.www.bussiapp.com Forum Index->E-Conference 1st March 2003
Author Message
upendra_purandare
SEFI Member
SEFI Member
PostPosted: Tue Mar 25, 2003 8:12 amPost subject: on Licensing Issues Reply with quote
Dear Mr. Rajiv,
It appears that my suggestion for making categories in licenses has been
grossly misinterpreted.
I certainly did not suggest different licenses for a framed structure or a
flat plate structure. But I feel there has to be a separate category in
license to authorise SE to undertake design of specialised structure (which
would require sophisticated tools of design supplemented by experience).
Should we allow a fresh engineer to take up a design of High-rise building
which could have many vertical and horizontal irregularities? Not
necessarily he will refuse to take up the assignment because he is not very
comfortable, rather he may be ready to take it as a challenge (at the cost
of risk of life of the occupants). Also, we can not disallow him from taking
up any assignment because he does not have any experience. Hence, I feel the
licensing authority should restrict the inexperienced engineers from taking
up certain type of assignments (if found incompetent during assessment
process which should be part of licensing system).
的re can be a general category license having certain restrictions, which
should be issued to anybody who is qualified. The other category
(unrestricted)should be issued after ascertaining the ability of the
engineer (not by the number of years criteria but through exam and/or
interview.
I have seen some people who were doing typical residential structures with
maximum G+3 stories for many years, do not have enough facilities (and
expertise?) to carry out analysis of high-rise buildings which they are
designing now. The simplified design procedures adopted by them do not
always result in conservative design. The number of years criteria without
any assessment (exam or interview) would generate reluctance among engineers
in updating (sometimes refreshing) their knowledge. Extending the same
logic, should the license be issued for life time? or should there be any
revalidation (after re-assessment) required after a certain period? Or can
we assume that all licensed engineers would upgrade their knowledge
regularly?
I do not believe that such system will kill innovativeness and creativity.
的eminent structural engineer from Delhi (mentioned by you)would be no way
restricted from designing unique/ outstanding structures. But I think some
kind of restrictions on relatively incompetent engineers is necessary.
Regards,
Upendra Purandare
Pune
Quote:
Reply-To:econf@www.bussiapp.com
To:upendra_purandare@hotmail.com
Subject: [ECONF] Re: [ECONF] on Licensing Issues
Date: Tue Mar 25 09:29:00 2003
e-Conference on ``Licensing Issues in Structural Engineering profession in
the Indian context`` organised by Structural Engineers Forum of India
(//www.bussiapp.com) under the aegis of Babtie Technical Assistance
Team as a part of the ADB Technical Assistance Project for Capacity
地震恢复和Reconst建筑ruction and Gujarat State
Disaster Management Authority
Dear All:
Mr. Alok Banerjee wrote
Quote:
2. the experience. Here, the criteria should be not the number of years
spent in designing but on the kinds os structures designed. Like our
friend
Quote:
Upendra from Pune said a person experienced in multi storey buildings
should
Quote:
be licensed only for multi-storey building because his experience of 10
yeras could be just a years multiplied by ten. Whereas, a person with
lesser
Quote:
number of years of experience but with a wider experience- bulildings,
industrial plants, roads, ESRs, could be licensed for more than one type
of
Quote:
structure.
I don't agree with Upendra and Alok. If we apply their logic, then it will
create a big havoc. By this logic we will have to have license for
designing
a framed structure, a flat plate structures, a shell structures, a folded
plate strucutres, a bridge structure... etc. because it is possible that an
engineer mayn't have designed all such structures. In my opinion it will
not
work at all. The idea of restricted license is to put the cart before the
horse.
的re is an eminent structural engineer in Delhi (well name isn't
necessary), who in last 40 years of his practice has designed many
outstanding structures. If we had such a draconian licensing procedure in
place then most of his structures would not be coming into existence,
because many of his structures were first of their kind in our country. So
be assured that the suggested system of licensing will only KILL the
innovation and creativity. We don't require such a licensing system and
must
reject it in toto. What is unnerving is that it is coming from a structural
engineer?
What we need is the sense of professional liability. If an engineer is
不舒服的一个特定类型的结构he will not accept such
an
assignment in the first place, when he considers his professional
liability.
That is the best safeguard for the society, a rigid licensing system is
不!
Thanks and regards
Truly
Rajiv Sharma
New Delhi
的views, opinions, analyses and assessments contained herein do not
necessarily reflect the views of SEFI and the Asian Development Bank, or
its Board of Directors or the governments they represent.
SEFI and the Asian Development Bank does not guarantee the accuracy of the
data included in the proceedings of this e-conference and accepts no
responsibility for any consequences of their use.
To make a posting to the e-conference, please send email to
To unsubscribe, please send an email tounsubscribe-econf@www.bussiapp.com
========powered by Reach1to1 Office Everywhere
(http://www.reach1to1.com)======
_________________________________________________________________
Protect your PC - get McAfee.com VirusScan Online
http://clinic.mcafee.com/clinic/ibuy/campaign.asp?cid=3963
Posted via Email
Back to top
View user's profileSend private message
alok_banerjee
SEFI Regulars
SEFI Regulars
PostPosted: Tue Mar 25, 2003 9:31 amPost subject: on Licensing Issues Reply with quote
Dear Rajiv,
You wrote
"What we need is the sense of professional liability. If an engineer is
an
liability.
不!"
This could be a part of the 'professional practice and ethics' (ppe) I
wrote at the end of my letter. With proper training and certification in PPE
we can deliver better. So PPE should form an important (most important ?)
part of the licensing process
Alok Banerjee
Mumbai
To:alok_banerjee@hotmail.com
Dear All:
friend
should
lesser
of
Quote:
structure.
designing
not
horse.
must
engineer?
an
liability.
不!
Thanks and regards
Truly
Rajiv Sharma
New Delhi
Go Bonkers over cricket with
http://server1.msn.co.in/msnspecials/bdm/index.asp Balram D Maity
Posted via Email
Back to top
alok_banerjee
SEFI Regulars
SEFI Regulars
Dear Rajiv,
an
liability.
不!"
Alok Banerjee
Mumbai
Dear All:
friend
should
lesser
of
Quote:
structure.
designing
not
horse.
must
engineer?
an
liability.
不!
Thanks and regards
Truly
Rajiv Sharma
New Delhi
Posted via Email
Back to top
rsmengr at eth.net
Guest
PostPosted: Tue Mar 25, 2003 1:38 pmPost subject: on Licensing Issues Reply with quote
Dear Upendra:
I haven't understood how a fresh engineer can enter into the business and
get hold of a large prestigious building project as outlined by you. But be
assured that such a mechanism will be in place. A person with PE license
will be someone who has passed his exams. and who possesses enough
experience to practice. He will be the person who will bear full
responsibility towards his work including professional liability.
So your fears on that part are unjustified because a fresh engineer will not
be able to acquire a PE license at the first instance. It will take several
years before he would be designing structures on his own.. If an engineer is
doing a new type of work than his work must be reviewed by a peer. That is
常见的这些天即使日常工作。
I have a strong belief that Structural Engineering is a profession of
challenges and opportunities. Higher the challenges, more the motivation to
learn and create something new. But for realising that one must have an
opportunity. By the restricted license this element of enthusiasm and desire
to do better will be lost. That is very much against the human nature and
that is the reason I reject this idea of restricted license.
At the same time I firmly believe in injecting the element of professional
liability in engineers' minds. But make him free of rigid restricted
licenses. Once they see the element of liability they will know their
limits. In U.S. many engineers have PE licenses but only a handful of them
actually use it because of very heavy professional laibility.
Thanks and regards
Truly
Rajiv Sharma
New Delhi
Posted via Email
Back to top
karkeer
SEFI Regulars
SEFI Regulars
PostPosted: Tue Mar 25, 2003 5:26 pmPost subject: on Licensing Issues Reply with quote
My suggestion is to conduct the examination and grade the level of engineer
based on his performance in the examination.The examination should cover all
possible type of structures and codal provisions so that one can be tested
for his capacity and he could improve his grade level say after 2/3 years
Shashidharan
Senior Lecturer
----- Original Message -----
To:
Sent: Tuesday, March 25, 2003 1:43 PM
Team as a part of the ADB Technical Assistance Project for Capacity Building
for Earthquake Rehabilitation and Reconstruction and Gujarat State Disaster
Quote:
Dear Mr. Rajiv,
(which
very
taking
the
taking
interview.
engineers
regularly?
way
Regards,
Upendra Purandare
Pune
in
State
Quote:
Dear All:
friend
should
lesser
type
Quote:
Quote:
of
Quote:
structure.
will
Quote:
designing
an
Quote:
not
horse.
So
must
structural
Quote:
Quote:
engineer?
an
liability.
不!
Thanks and regards
Truly
Rajiv Sharma
New Delhi
the
Quote:
Posted via Email
Back to top
karkeer
SEFI Regulars
SEFI Regulars
Shashidharan
Senior Lecturer
To:
Quote:
Dear Mr. Rajiv,
(which
very
taking
the
taking
interview.
engineers
regularly?
way
Regards,
Upendra Purandare
Pune
in
State
Quote:
Dear All:
friend
should
lesser
type
Quote:
Quote:
of
Quote:
structure.
will
Quote:
designing
an
Quote:
not
horse.
So
must
structural
Quote:
Quote:
engineer?
an
liability.
不!
Thanks and regards
Truly
Rajiv Sharma
New Delhi
the
Quote:
Posted via Email
Back to top
ishacon1
PostPosted: Wed Mar 26, 2003 12:37 amPost subject: on Licensing Issues Reply with quote
Dear Rajiv,
You are absolutely correct that licensing should be there alongwith Ethics
in Professional Practice -A VERY IMPORTANT ISSUE.
In the USA, one takes a P.E. license exam of 8 hrs duration only after min
of 4 years of experience
under a P.E. after Bachelor's degree and that too only if he has cleared the
Fundamentals of Engg exam of 8 hrs. Even the experience is evaluated by the
Board to assess if it meets the
requirements and it is not 1 year experience repeated 4 times !
I do not agree with others comments that persons above 60 years age should
not be members of ECI etc.
In fact one has to draw on the rich experience of these individuals who are
now more into management
and have developed contacts with people in the Govt. or the industry.
In fact one of the problems that will be faced would be to make up a Board
for Registration of Engineers where
all Govt. bodies will like to get their finger in the pie so that political
pressures are exerted even in this process.
All engineers must unite to thwart such unholy moves. On one hand, the
various ministries or Govt. departments
can not be ignored but adequate representation from professional bodies has
to be there as well.
Someone suggested SEFI to become an official profesional body for regn of
structural engineers. This can be possible only if it is appropriately regd.
first with Registrar of Societies but I hope you are aware that one Indian
Association of Structural Engineers has already been set up and duly regd.
总部在新德里。这将是一段时间之前e its representation comes
up with ECI.
And if AICTE gets to do the Registration of Engineers thru a Board of
Registration set up by them, then ECI 's basic
objective will be lost. In fact they AICTE will have to set up a Board of
Ethics as well,
where persons of proven Integrity will need to be taken on Board.
Unless this issue is resolved ASAP, the engineering fraternity will
continue to suffer.
But there is a ray of hope - since WTO negotiations and GATS clause need to
be addressed urgently, I think
that the impasse over the Regn issue would be resolved soon if Institution
of Engineers can decide
which side of the fence they wish to be on and the Govt. acts fast. This is
possible only if we stand united
and the Professors of esteemed engg istitutes make an urgent representation
to Ministry of HRD.
One must not forget that even if one takes the P.E. licence say after 7
years of experience after B.E.
or 6 years after M.E., one has to accumulate Continuing Education credits in
order that the Licence gets renewed
in every 3 to 5 years period. And the licence can get revoked if this is not
complied with.
Even the Insurance sector will need to shape up to offer Professional
Liability insurance for Engineers.
Regards,
V.P.Agarwal
ishacon@vsnl.net
Posted via Email
Back to top
Display posts from previous:
This forum is locked: you cannot post, reply to, or edit topics.This topic is locked: you cannot edit posts or make replies. www.www.bussiapp.com Forum Index->E-Conference 1st March 2003 All times are GMT
Page1of1
Jump to:
Youcanattach files in this forum
