www.www.bussiapp.com
Forum SubscriptionsSubscriptionsDigestDigest PreferencesFAQFAQSearchSearchMemberlistMemberlistUsergroupsUsergroupsRegisterRegisterFAQ安全提示FAQDonate
Use online scanners
Message No 28 - Corten Steel
This forum is locked: you cannot post, reply to, or edit topics.这个话题被锁:可以not edit posts or make replies. www.www.bussiapp.com Forum Index->E-Conference 20th June 2005
Author Message
inchak at tatasteel.com
Guest
PostPosted: Tue Jul 12, 2005 6:24 amPost subject: Message No 28 - Corten Steel Reply with quote
Dear Mr. Vijay Patil
Thank you very much for a very important question
QUOTE
"I believe there is a steel called corten steel. It is supposed to have a
sacrificial layer which in turn protects the inner layer.
However it is not clear whether such steel is only for structural steel
plates or can be for reinforcement bars too"
UNQUOTE
REPLY:
Corten steel is ONLY for structurals and other steel components which are
open to atmospheric corrosion. This is NOT suitable for reinforcement bars
CORTEN matches with WR-Fe 480A of IS 11587 - SPECIFICATION FOR STRUCTURAL
WEATHER RESISTANT STEELS it depends on the following corrosion resisting
elements:
P 0.08
Si 0.4
Cr 0.4
Ni 0.3
Cu 0.5
While it is good for Weather resistance it will not perform well when
embedded in concrete.
I draw your attention to the NOTE 3 of AMENDMENT NO. 2 MAY 2002.to IS 1786
which speels this out in clear terms as under:
"User may note that there is a danger of pitting and crevice corrosion when
weathering steels (that is, those with chemical composition conforming to
IS 11587 : 1986 ‘Specification for structural weather resistant steel’ are
embedded in chloride contaminated concrete"
Trust this clarifies your doubt.
Indranil Chakrabarti
********************************DISCLAIMER***********************************
Information contained and transmitted by this e-mail is confidential and
proprietary to Tata Steel Ltd. and is intended for use only by the
addressee. If you are not the intended recipient , you are notified that
any dissemination or copying of this e-mail is strictly prohibited and you
are requested to delete this e-mail immediately and notify the originator.
Tata Steel does not enter into any binding agreement with any party by
e-mail. Any views expressed by an individual do not necessarily reflect the
view of Tata Steel. Tata Steel is not responsible for the consequences of
any actions taken on the basis of information provided. While this e-mail
has been checked for all known viruses the addressee should also scan for
viruses. To know more about Tata Steel please visitwww.tatasteel.com
Posted via Email
Back to top
Display posts from previous:
This forum is locked: you cannot post, reply to, or edit topics.这个话题被锁:可以not edit posts or make replies. www.www.bussiapp.com Forum Index->E-Conference 20th June 2005 All times are GMT
Page1of1
Jump to:
Youcanattach files in this forum
发布或接受一个广告是不ither a guarantee nor endorsement of the advertiser's product or service.advertisement policy
