www.www.bussiapp.com
Forum SubscriptionsSubscriptionsDigestDigest PreferencesFAQFAQSearchSearchMemberlistMemberlistUsergroupsUsergroupsRegisterRegisterFAQSecurity TipsFAQDonate
Use online scanners
Some questions about concrete
This forum is locked: you cannot post, reply to, or edit topics.This topic is locked: you cannot edit posts or make replies. www.www.bussiapp.com Forum Index->Past Discussions Year 2004
Author Message
suraj
General Sponsor
General Sponsor
Location: NCR Faridabad, E mail suraj_engineer@yahoo.co.uk
PostPosted: Wed Dec 22, 2004 5:32 amPost subject: Some questions about concrete Reply with quote
Structural concrete pour
Some simple practical questions about concrete for the budding engineers
Concrete of grade 35 or 40N is to be poured
Acceptable slump is 125+/- 25mm
Temperature of concrete 26 deg C
At delivery time slump is observed 200mm
What should be done? Reject or accept the truck?
Cubes fail on 7th day test. What should be done ?
What should be preferred for curing of concrete
Curing compound or water
Eng Suraj Singh PE
Posted via Email
Back to top
View user's profileSend private messageVisit poster's website
kagarwal
SEFI Member
SEFI Member
PostPosted: Wed Dec 22, 2004 9:04 amPost subject: Some questions about concrete Reply with quote
Dear members.
I am designing a 9 story building near noida. The site is rocky having
bearing capacity around 21t/m^2. I am trying to proceed with isolated
and combined footing as recommended by soil consultant. Is there any
codal provision, restricting the use of isolated/combined footing in
such cases.
Thanks
Kapish
-----Original Message-----
Message From rccbuildings2@yahoo.co.uk [mailto:rccbuildings2@yahoo.co.uk]
Sent: Wednesday, December 22, 2004 4:32 PM
To: Kapish Agarwal
Subject: Some questions about concrete
Eng Suraj Singh PE
ALL-NEW Yahoo! Messenger - all new features - even more fun!
Posted via Email
Back to top
suraj
General Sponsor
General Sponsor
PostPosted: Wed Dec 22, 2004 10:17 amPost subject: Some questions about concrete Reply with quote
It is suggested to design beams frame foundation for such case
kagarwal@desein.com写道:
Dear members.
such cases.
Thanks
Kapish
To: Kapish Agarwal
Eng Suraj Singh PE
Posted via Email
Back to top
chordia1
SEFI Member
SEFI Member
PostPosted: Wed Dec 22, 2004 11:14 amPost subject: Some questions about concrete Reply with quote
There is no codal provision one can easily go in for combination of Isolated
and Combined footing and to be more causious connect it with stiching slab.
Regards
sanjeevJain
----- Original Message -----
Message From
To:
Sent: Wednesday, December 22, 2004 3:50 PM
Dear members.
such cases.
Thanks
Kapish
To: Kapish Agarwal
Eng Suraj Singh PE
Quote:
Posted via Email
Back to top
sidhudaljeet
PostPosted: Wed Dec 22, 2004 2:19 pmPost subject: Some questions about concrete Reply with quote
Slump 200 is too much, 125 is also on heigher side, if you pump conc. it is all right.
Take sample of the mix, just check how much water it has. simply dry the conc, this way you would be able to know the water cement ratio. since slump is very rough idea of water cement ratio.
7 days sample gennerally fails due to curing at low temp, if the ambient temp is above 30, 7 days strength should be allright.
if water cement ratio comes much more than the specified, it might be poor conc.
it should be rejected.
Daljeet
Eng Suraj Singh PE
Posted via Email
Back to top
raju_goa
SEFI Regulars
SEFI Regulars
PostPosted: Wed Dec 22, 2004 3:56 pmPost subject: Some questions about concrete Reply with quote
Hi Kapish,
There is no codal provision restricting use of isolated / combined footings.
You can opt for isolated footings and possibly combined footings if the
footings overlap. It would be ideal to tie the columns at plinth level with
plinth beams.
Shekhar Panandiker
Goa.
Posted via Email
Back to top
James_Cohen
SEFI Regulars
SEFI Regulars
PostPosted: Wed Dec 22, 2004 4:10 pmPost subject: Some questions about concrete Reply with quote
Dear Mr. Singh,
如果衰退和低强度高的结果are for the same pour, the
concrete should be rejected before additional construction takes place. If
the specification called for a specific 7-day strength, this is usually done
to provide the contractor with "advance notice" that there may be a problem.
So, if the low-strength results are local, I would advise halting
construction in that area until additional strength tests are completed. It
is best to stop further construction until either 14-day test results can
establish the adequacy of the concrete or to remove and replace the affected
area. The contractor is unlikely to want to wait for 28-day results and you
and the owner are unlikely to want additional construction to occur which
may need to be removed or substantially altered. If the problem is endemic
to the entire structure, the available choices are not good, but still need
to be resolved.
An alternative approach is to re-analyze the structure with the lower
results. Design is typically predicated on a rather high factor of safety,
part of which is based on unknown material strengths and unknown
construction tolerances. If these are known, as should be the case in your
situation, these factors of safety are no longer required. It may be that
the actual strength is still adequate to provide the required residual
factor of safety. In situ testing may also help to establish that the
concrete does have the necessary strength to remain with little or no
strengthening.
James Cohen, PE
James Cohen Consulting, PC
http://expertpages.com/jccpc
Posted via Email
Back to top
rajmane
PostPosted: Thu Dec 23, 2004 2:07 pmPost subject: Some questions about concrete Reply with quote
23rd Dec 2004
Dear all
(1)" Concrete of grade 35 or 40N is to be poured, Acceptable slump is
125+/- 25mm, Temperature of concrete 26 deg C,
At delivery time slump is observed 200mm"
I think the concrete need not be rejected provided the increased slump
does not cause any construction problems. It is almost to produce
concrete every time with the same slump. This is a fact. I think more
emphasis should be on parameters such as : (a) cohesiveness, (b)
non-seggregability, (c)no excessive bleeding, (c) Correct setting
property, etc.
(2) "Cubes fail on 7th day test". The reasons for this should be studied
in any particular case. Some parameters to be looked into are: Change in
cement and admixture type and content (b) Change in materials, (c)
Actual curing regime followed, (d) Method of testing, loading rate etc,
(d) Status of test specimen, defects if ant in specimen, (e) Calibration
of testing machine. etc. If all these can be satisfactorily looked into,
then, NDT on structures including core sampling should be considered. 7
一天只是一个力量indicator and not the final criterion for
acceptance or rejection of concrete as per IS:456-2000.
(3) "What should be preferred for curing of concrete, Curing compound or
water"
Water curing must be always preferred. However, with expert supervision
(not usual normal supervision), curing compound can be used. Any project
engineer/site supervisor should develop a proper quality check and
application methodology.
(4) The suggestion of "simply dry the conc, this way you would be able
to know the water cement ratio" is not rational. This way w/c can not be
determined. I do not know in which reference/standard published works,
this suggestion is available. Drying (in hot air oven) causes further
hydration of cement and this does not get reflected in weight loss. we
can send endlessly on the problems/difficulties in accepting this
suggestion. I draw the attention of Neville's one paper in Concrete
International where he hoped that some day some body will find
acceptable/correct way to find w/c of fresh concrete after it is mixed.
Thank you all
N P Rajamane
Deputy Director and Head, CCL, SERC, CSIR, Chennai
600113
Ph: 22549152 (O), 24417882 (R), 9840076821
Fax: 22541508
Posted via Email
Back to top
suraj
General Sponsor
General Sponsor
PostPosted: Thu Dec 23, 2004 3:52 pmPost subject: Some questions about concrete Reply with quote
Dear Sir,
Impressed by the your explanation
Eng Suraj Singh PE
rajmane@sercm.csir.res.in wrote:
23rd Dec 2004
Dear all
property, etc.
water"
Thank you all
N P Rajamane
600113
Fax: 22541508
Posted via Email
Back to top
vikramjeet
SEFI Member
SEFI Member
PostPosted: Wed Dec 29, 2004 6:46 amPost subject: Some questions about concrete Reply with quote
Dear kapish
Isolated Footings are economical vis -a - other type of footings /
Raft.However, since the structure is
located in Zone - 4 It is advisable to tie the isolated footigs at
foundatioin Level itself in both
directions .Tie beams will also take care of Moments at footing LvL
due to gravity loads & Seismic.
Regards
Jeet
Posted via Email
Back to top
Display posts from previous:
This forum is locked: you cannot post, reply to, or edit topics.This topic is locked: you cannot edit posts or make replies. www.www.bussiapp.com Forum Index->Past Discussions Year 2004 All times are GMT
Page1of1
Jump to:
Youcanattach files in this forum
发布或接受一个广告是不ither a guarantee nor endorsement of the advertiser's product or service.advertisement policy
