rejizac 188金宝搏ios官方app下载SEFI成员
加入:2011年5月20日 职位:4
发布:2016年2月19日,星期五下午2点文章主题:质量改进是整合前的路吗? |
亲爱的所有, � 是悲伤,土木工程质量实行的国家减少日复一日在各领域建设。��我们自己被指责,我们可以让它正确。��After touching and integrating many of these aspects in my career, let me put down some points.. � 首先,老年人在我们要指责严重不考虑任何变化的趋势在过去的40年。之前工程师施工全面管理。�The next generation off loaded the responsibility of construction to many other hands like, Architects, Builders etc.� � 我们只负责生活,我们需要控制。��Now you would say there is no law in the land to put it that way.��Actually we are law makers ourselves, as we control the construction through many instruction in the general notes we give along with the drawings. Now�Sefi�may introduce a common general notes or our constitution which is to be followed in all sites through these drawings.��For example, Constitution/law do not give parking spaces��for auto rikshaws or taxi. They fix it themselves and no body is going to complain about that when there is strong common sense behind these. We should act in the same way. Let us make our own laws and implement it too. Nobody else is going to understand or support you.
另一个重要的一点是,你不让别人做你应该做的工作。他们所做的是,他们所做的工作不同的工程师和他们一起组装起来知道受试者在一个邮局。我们设计工程师、计划工程师、评估工程师、质量管理工程师、现场工程师为他们工作。他获得报酬,但你不是。公众不明白工程师做什么,因为他们只看到对方的脸。你需要直接处理公共和吃苦头。你可以更快的和有效的。�If at all client wants cosmetic or functionality you get an architect to work for you on that project. After practicing most topics in civil engineering including structural design, detailing, software development, erp software, estimation, geotechnical, planning, construction management and architecture I think the last one requires the least effort. Public should also understand that in construction engineer is your friend who reduces your cost where as all others adds to that. � 建筑需要良好的大脑的右侧,而工程需要左侧。好的架构师因此并不好工程师,反之亦然。如果国家想要安全结构,让工程师做他们的责任,只有工程师应该监督另一个工程师的工作。同行评审/检查员是必须的。没有人理解这些作品。�Thus all infra structure and building construction should be based on this. � 另一个问题是在印度的教育制度实行。我的一个常见的面试问题。技术工作或实习是阿基米德定律和定义。我采访了大约400名工程师。没有人给过我答案正确,除了一个或两个。它是由阿基米德发明在公元前250年。我们的学生还没有理解这一点,他们并不适用于结构。�Leave the students, some of the university professors who got Phd from IITs are yet to understand the same. Some of the top consultants have spent clients crores of rupees not understanding Archimedes.��Problem lies with the teachers. Our education systems is depending on notes given by teachers. This is to be stopped. All exams should be open text book exams from high school itself to know if they have understood the real theory and applied it. � 应用程序级别的教学非常重要的我们不知道为什么我们要学习许多科目。例如数学主题对于工程师不教与应用程序。数学作为一个大工具在分析情况,我们缺乏的使用它由于相同的。��学生应该从课本中学习,而不是从notes由讲师。只有这样他们会知道学习的艺术信息在互联网和其他库。188金宝搏ios官方app下载Sefians应该站出来支持一个入学考试,筛选是由多项选择,然后那些合格,打开课本考试第二部分。通过引进这样的系统,它将冲击波通过教育水平甚至从小学。 � 一所小学学生给出一组方程,���,它减少了教师工作的解释。相同的学生心中所有的土木工程方程而不是理解或派生。方程的数量超过成千他们不使用或记住它的应用程序。还没有我的工程师曾经告诉我如何一起做基础,基础和挡土墙是��他们所知道的只是基础和挡土墙。��When will we ever stop teaching��civil engineering as different members alone like slab, beam, column, pile, footing, retaining wall or the theory behind all these members as a unified one? � 大量的交互是可能的与上面提到的工程学科,以方便施工的力量。作为工程师办公室做所有的工作在相同的环境中,会提高系统的速度和精度。看超级出租车,他们旅行的费用减少到50%或小的总体集成。在建设中,可以节省100%的成本与相同的建筑。我们浪费创造硕士不减少。一个简单的例子是,我们做一个别墅里2年5个月,实际上是可能通过整合服务。我们失去20%的利息成本仅在5000卢比每平方英尺的别墅。如果土木建筑的成本是Rs 1000每平方英尺,我们宽松的时间独处。至少有15参数我们宽松的另外的地方。 � 看看我们的工程师,他们不使用自己的软件编程。离开它,他们甚至不知道的关键。25年前我在工程学院提交的作业类型在他们的历史上第一次。尽管有反对老师我可以强迫他们接受它。它提高了我的打字技能,这可能是为什么我打字今天��来表达我的观点。 � 研究需要和哪个国家不实行任何地方。如果我只有IIT钦奈女士课程促进研究。感谢我们的下午我读了10个这样的单位将在yeterday设立其他地方的新闻。��There should be a grants and support from the Govt in research to reduce the cost��of construction in India. Being the largest area of Govt spending, research can save a part of this amount. Many of the research we presently do is not of use to common practice, and before funding the impact needs to be valued. � 部长问了一个问题领域他们应该做些什么来支持它2001年在高知县的研讨会和科学顾问厘米,钱德拉巴布·纳都是椅子上的人说,你可以做的最好的事情就是远离这个。在我看来政府和政府支持的公司应该远离真正的在其他国家建设为实践。政府应该做什么是审计人员在全国各地就像电检查员检查建筑活动。我们社会的奶油出国或去印度政府和他们不工作了。所有PWD, CPWD家什系统修改只检查他们正在以20%的效率水平。还与政府工程师以任何方式连接必须分开决策机构,因为他们是一个系统的一部分工作效率很低。 � 问候,
Reji撒迦利亚�B.Tech。,mba学位� M。 IIT钦奈。 ��
结构顾问
移动�+ 919846026162 识别顾问,�结构&岩土工程顾问, 二楼,�识别建筑,Soonoro教堂1日交叉路, Elamkulam,喀拉拉邦,印度科钦20日。 电话�+ 914843241537���传真+ 914842322532 坐标:9.965968,76.308463� 电子邮件:�r (srconsultants@eth.net)ejizac2004@gmail.com (ejizac2004@gmail.com) www.sandrconsultants.com� www.aadspro.com
skype id:�rejizac google talk id:�rejizac2004@gmail.com (rejizac2004@gmail.com)
Reji ZachariahTo印度总理 2月15日(4天前)
Reji撒迦利亚�< rejizac2004@gmail.com (rejizac2004@gmail.com)> 2月16日(3天前)
对�Sreehari
pl在适当的格式
Reji撒迦利亚�B.Tech。,mba,M.S.Mobile�+ 919846026162 识别顾问,�结构&岩土工程顾问, 二楼,�识别建筑,Soonoro教堂1日交叉路, Elamkulam,喀拉拉邦,印度科钦20日。 电话�+ 914843241537���传真+ 914842322532 坐标:9.965968,76.308463� 电子邮件:�r (srconsultants@eth.net)ejizac2004@gmail.com (ejizac2004@gmail.com) www.sandrconsultants.com� www.aadspro.com
加入:2008年4月17日 帖子:5553 地点:NCR法里达巴德,E邮件suraj_engineer@yahoo.co.uk
发布:坐2月20日,2016年上升文章主题:根源——部分工程师& ISO 9001 |
根源——部分工程师& ISO 9001
写论文不会努力提高Engineersquality标准
指责老年人也应,不支持任何东西
我在工程行业已经超过35年&经验丰富的建筑工程的深度问题
我们曾经工作在所有的子学科,成为从一开始,当没有它和ISO 9001
每个工程师被迫认为各种主题分析所有问题的现场解决方案以及设计的办公室
天的工作在画板远比天现在在电脑上工作
事实上,效率提高了很多次,butquality产品急剧恶化
我惊讶地看到许多修正categoriesof从原理图设计图纸工作&红线
涉及到许多手&质量crushedto
ISO已经改变了整个场景,Planningengineer在现场不感兴趣的作品,设计师在rebarassembly不感兴趣,质量人认为他应该充当警察,QS认为herequires只估值格式合同&规格,而网站工程师﹐科文完全无助
甚至,工程师interactwith其他学科不感兴趣,这是非常重要的
设计师不值输入fromHVAC,电器和电子产品和安全
跟上这种情况下,我们认为质量生产
工程使用是非常困难的disciplineduring教育缺乏电脑和计算器
心中合格的工程师曾经likecalculator &电脑&结合工作经验和实用主义,anassessment可以,设计是否安全
很多学习网站问题可能产生realengineers &工程师不像帕拉状态工程师工作现在即使在GCC,到处都找不到真正的工程师,对完成工作
保持所有这些问题,ISO 9001 - 2015 hasoverhauled ISO 9001 - 2008年,拉到质量管理体系在各领域的领导includingbusiness流程
质量经理已经几乎把报纸工作水平的现状授权工程警察
头都作为qualityissues领导工作,这将是一项艰巨的任务指令管理
所有进程制定基于风险控制&不是独家的预防措施
成本的过程一定下来参与工程师属于不同的学科应当onhigher概要文件
